I got a call from my in-laws yesterday who told me their roof started suddenly leaking during a rain shower. I got up on the roof and didn’t observe any clearly visible defects at first, however what I found was a great learning experience for me. Given the low slope of the roof (3:12 I think) water is pooling at the edge of the shingles, particularly in this area where the leak occurred. The roof decking felt soft in this area and the adhesive is worn out and the shingles can be easily lifted up in this area:
The roof is only 18 years old, which is nowhere near the standard 30-40 service life of architectural shingles. Is it common knowledge that a lower pitched roof like this reduces the expected service lift of asphalt shingles? Is there a different kind of roofing that you experts would recommend for a lower pitched roof like this other than metal roofing?
Were you able to lift the edge of the shingles and see if there is any under layment? My guess is that there is not. This would lead to leaks on that low slope roof. A Mod Bit or modified bitumen or EPDM roof covering would work well there. If you want to maintain the look of an asphalt shingle roof, just re roof with a good grade architectural shingle and do a double layer of 15 lb felt under layment first.
As an alternative, I prefer covering the entire wood roof deck with ice and water shield before applying the architectural shingles for a like roof slope.
I’ve never lived where a composition shingle looks good at 30. Perhaps we disagree on what is “service life.” I’ve seen a very ugly roof that is still keeping water on top of it, but you can’t get insurance for that roof.
That’s what I’ve been wondering. Water could have been coming in at the sidewall, it looks like there’s bare wood under the soffit. Or anywhere else other than pooling.
Architectural shingles should have at least a 412 roof pitch, so water is probably soaking through the shingles and leaking? It also might be leaking from somewhere totally different than what’s being shown inside the house.
1. Low Slope Requirements (2:12 to 4:12 Pitch)
On slopes between 2:12 and less than 4:12, water drains much slower. GAF requires specialized underlayment protection to prevent water intrusion:
Double Layer of Synthetic Underlayment: You must lay two overlapping layers of felt/synthetic underlayment (such as GAF FeltBuster or Deck-Armor), OR
Self-Adhering Leak Barrier: Install a full layer of self-adhered ice & water shield membrane (such as GAF WeatherWatch or LeakBarrier) across the entire roof deck area.
That works, what it is not saying is too tuck the top of the shingles under the underlayment every 18 inches, if water gets under the shingles it has a exit point every 18 inches.
My first thought was, what did you see in the attic? A spot in the ceiling doesn’t necessarily mean a leak directly above as we all know water can travel a rafter before it decides to drop. That would have been one f my reasons for checking the attic first. The other is that a leak you can see inside can mean a persistent leak that finally made its way through the insulation. In such a case it’s possible the roof decking is compromised. I’d want to know the condition of the decking before I go topside.
