http://www.youtube.com/watch?v=EzqxPXDULW0 ](,)](,)](,)](,)](*,)
ALL these companies either don’t care where/why water is entering your basement or don’t know (duh incompetent). If you don’t stop the water from entering your not going to stop-prevent mold. They’ll often try and tell you all you need is an EZ Breathe system installed with the perimeter basement system and they often will cover the basement wall(s) with a vapor barrier etc and all that does is hide/conceal water that is coming in, mold, efflorescence and the actual CONDITION of the basement wall.
1:50 in video… “a vapor barrier is installed to prevent foundation moisture”
What in gods name are they talking about!!! That junk in NO WAY, stops/prevents water etc from entering through ANY exterior openings/cracks.
That pffftttt ‘vapor barrier’ is only going to HIDE water, mold etc.
It’ll conceal any possible problem with any basement wall, cracks, bowing etc… hello!
This is what most often happens, causes, wet leaky basements…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183496301296754
This is where the water FIRST entered into the block foundation wall
And here…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183604679367970
In part, what CAUSED the exterior cracks in foundation wall
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183457360199010
What the foundation wall looked like from INSIDE the basement, same corner
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183658241638370
And where the water entered, was seen, in the basement, which most often is along the bottom of the basement wall, floor… wall-floor joint, cover, cold joint, I-joint, whatever
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing09#5442183716262161106
And these misfit, lying interior system companies try and tell you, bs you, that because you see/get water along the floor-wall joint it is supposedly because of that moronic incompetent lie of hydrostatic pressure problem under your floor.
Well, just posted photos of this homeowners house/problem, they would see water along the bottom of wall, floor joint…they almost got scammed by an inside system company. How many other photos do some need to see, duh.
These poor people got scammed by AquaGuard waterproofing…short video
Same homeowner SUED this scammball company…
Different homeowner hired Vulcan basement waterproofing, morons
http://www.youtube.com/watch?v=YCkcVURSO1U
