Leaky basement, poured wall crack was injected... leaks
house for sale…
no floor drain or they covered over a possible F drain (flooring)
IMG_8400|375x500
Foundation systems of Michigan “repaired” this one. In case you can’t see it, water is leaking through their fastener holes…:slight_smile:
they often try and talk homeowner into int drainage system but apparently not at this house
hope things are good Mike, thanks for the photo
