and pretty much all interior system companies do NOT understand or care to know and what Ames research here doesn’t ‘get’ either and simply wants to sell their blue max to as many unknowing homeowners as possible…
Waterproofing and fixing basements leaks with Ames Blue Max
See the cracks on interior block wall, huh?
This guy ‘spins’, misinforms etc that this blue max from Ames is all homeowners need to do, to slap on their basement walls… “It filled in this crack”… pfffttt!!! “Non permeable, flexible SEAL…”
–For technical assistance 888 345 0809 #-o
Bubba has some 'assistance he’d like TA share wiff ya’s, got milk? Huh?
LOOK, here’s 1 of many homes with block basement walls that had the same type of vertical crack that one could see on the inside, even when the wall had been painted (if they opened their eyeballs), yeah, home inspector didn’t care about/see the crack, discolorment of blocks etc
Here’s the house…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905732604350215362
Problem area, leaky area, between the front porch and corner
Seller had raised and sloped the grade, see? loool
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905732936414196722
Inside the basement between the porch and corner…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905729685154332562
Basement walls were painted, would NOT have mattered AT ALL if someone used Blue max stuff by Ames or Drylok etc, NO!
Bottom of wall between porch and corner
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905729854904975202
Hairline vertical crack on inside, should have paid much more attention/thought to it, to the mold and efflorescence etc, duh!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905729917032593826
The corner up high
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905729980221789506
Corner down low
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905730044285413778
Outside, outside, outside, between porch and corner…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905733445109847218
Water enters here, and 1 reason why there is some mold and efflorescence on inside blocks
Outside, the VERTICAL crack… same dang crack seen inside!@!@!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905734405008876818
Vertical crack, and ya best believe these cracks and other exterior openings allow water in basements, and why there is some mold, efflorescence etc
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905734213684952146
And what MOST do NOT understand and apparently don’t care to, don’t want to (big babies!!!) is, you cannot ‘inspect’, know, see, ALL possible exterior cracks just by looking at the inside of these block walls, basement walls OR crawlspace walls
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905734783321178610
Horizontal crack, helllllllllllo!
Eh, do home inspectors or even structural engineers GET THIS sht? Huh? loool
Some tell homeowners to hire an HI etc for an unbiased opinion on their leaky basement. Well DUHHHH!!
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing72#5905734965153894898
That unbiased opinion and cost won’t mean Sqqqqqqqqqqqqqqqqqqquat if they don’t understand there can be exterior cracks and other exterior openings in block walls, brick walls, even though they don’t see a dang thing on the inside!!!
Some exterior cracks are wider…
http://picasaweb.google.com/101049034584960315932/BasementWaterproofing12#5442257934740023314
Sometimes, some blocks will disintegrate, deteriorate like this…
http://picasaweb.google.com/101049034584960315932/Crawlspace#5540665133328086770
So when a homeowner has a leaky basement, maybe some mold or efflorescence on some blocks then, sheesh loool, one should be trying to identify/locate/detect HOW-WHY-WHERE they leak and not just stroll over there and tell every homeowner they need to apply Blue Max or Drylok or install a moronic interior basement drainage system.
And another lil lesson some should have learned here is (ahem!), raising and sloping the soil, the grade, does NOT… has not, identified ANY homeowners actual problem, leak!!!
Cuckoo tweety bird http://www.youtube.com/watch?v=d1WcxRaMmIM
Cuckoo clock http://www.youtube.com/watch?v=G8GwT7ZotCg
Time has come TAday/Chambers Bros… cuckoo! http://www.youtube.com/watch?v=_zfgoJzOCgg
