Load and non-load bearing wall image
As I am going through this course I found an image that seems a bit off. On the left of this house it shows the exterior wall as non-load bearing, and on the right it shows the exterior wall as load bearing. Is this correct? Am I looking at the image wrong? Or is this mislabeled for the left exterior wall?
The arrow is not pointing to the exterior wall. it is pointing to the closet wall a few feet in from the exterior. The drawing is correct.
I agree that the drawing could be better. You have to look close to see the distinction.
The exterior walls are load bearing. The center wall may also be load bearing. Nice catch.
I am sure the staff will catch this and correct it. Those also are not roof trusses. Those are rafters.
Looks like a fink truss to me. Yes, it’s not the best drawing.
How to Build a Fink Truss: Complete Step-by-Step Guide
next project for @zupright perhaps???
Thank you, Kelly.
I think the illustration needs to be better defined.
I concur with Kelly and Charles on this. As soon as I looked at the illustration the closet wall/knee wall are not represented well.
At the least: Load bearing walls studs, should be a unique color.
Non-Load bearing walls studs, should be a unique color.
Note: Load bearing, non-load bearing center walls is also suspect.
Kelly, this should be sent to Ben Gromicko at education. www.internachi.edu Link the thread with the emial.
The roof framing as drawn is not an engineered truss its a stick built roof with braces. So the interior walls will have some loading, because the ceiling rafters are typically lapped over on of the hallway walls.
Yeah man, that image does need an overhaul. I’ll add it to my list and upload as a draft image to review. Thanks for the heads up!
I am open to learning something new. Do web members get installed using the shear strength from the nails. I just have never seen that before. I will do some digging. But I have never seen a truss without gusset plates. I have seen metal, and wood plates, but never have I ever seen where a web member being held together by a nail on the side. I would love to see the drawings on this one.
If you guys recall, back in 2009, skinny homes were all the rage; long before tiny homes. It was the wild west and no standards had been established :smile:
I bet it had a nice cross breeze too.
Hi Charles,
I don’t see any nails, screws, nail-plates, bolts, staples, or fasteners of any type in this drawing. I guess I assumed the fasteners because only wood and concrete are pictured in this rough sketch. I may have assumed wrong.
The drawing is labeled as a “truss” and, minus any fasteners, it is a fink truss. It’s not the best drawing, I may have assumed wrong. You could be right also. It could be fastened with nails. Only the illustrator knows the answer to that mystery. Nice catch.
