Location of compression and tension of beams
The compression and tension of a beam are opposite at the end the of the beam, such as a cantilever as to the middle of the beam. The compression is at the bottom and the tension is at the top of the cantilever. The middle of the beam, that is properly supported, the tension is on the bottom and the compression is at the top.
