Looking for Advice on Handling Moisture Issues Found During Home Inspection
Hi everyone,
I’m glad to be part of this community and learn from experienced inspectors here. I recently came across a situation during a home inspection where I noticed signs of possible moisture problems around a basement area. There were some stains and a slight musty smell, but I’m not sure if it points to a minor issue or something that needs further investigation.
I’d appreciate hearing from other inspectors about how you usually approach these situations and what steps you recommend before suggesting repairs to the homeowner. Any advice or experiences would be helpful. Thanks!
Per the NACHI SoP, we are to report on any signs of active moisture intrusion. I would not concern myself with minor or major. Water intrusion needs to be reported and corrected.
That likely indicates elevated humidity, corresponding moisture issues, and possibly fungal or mold growth. Tread carefully here and look diligently for moisture-related issues at walls, floors, and structure.
All you need to do is report what you find (see, smell, taste touch). Home Inspectors do NOT diagnose (major or minor). Just write what you see. This will most often need further evaluation by a specialist.
Unless you’re qualified to do so, you wouldn’t suggest any repairs to the homeowner. Refer it out for further evaluation by a qualified specialist.
You report what you see and smell! It is not up to you to design the repairs. When our inspectors find this, we simply tell our client that the cause needs to be investigated by a basement/crawlspace drying specialist to determine the best course of action to correct the issue.
I would be more concerned with attempting to determine “Minor” from “Major”, and what your plan to mitigate risk for your decision is? If you’re gonna get involved in that game, you best have a boatload of education, great insurance, and a really expensive Attorney on your side!!
Thanks everyone for the helpful feedback. That makes a lot of sense. I can see now that my role is to clearly document what I observe rather than trying to judge whether the moisture issue is minor or major or recommend a specific repair. Reporting the signs, noting any moisture-related concerns, and recommending evaluation by the appropriate specialist seems like the safest and most professional approach. I appreciate all of you sharing your experience, it definitely helps me better understand how to handle these situations going forward.
