Originally Posted By: cbottger This post was automatically imported from our archived forum.
Mike
There you go that is part of the problem with a Delta T or TD of 24 degrees you are not out of range. Who in the world would want a return of 64 degrees the unit would have to run non stop to achieve those kinds of temperatures I prefer a cool home but that would be cold enough to hang meat. ![icon_cool.gif](upload://oPnLkqdJc33Dyf2uA3TQwRkfhwd.gif)
I inspected a home last summer that had the A-coil drain pan with holes the size of silver dollars draining straight into the plenum. The home had a crawl space and I observed water dripping from the plenum under the home and water leaking from the ducts approximately 20 feet downstream from the plenum.
-- Don't argue with an idiot someone watching may not be able to tell the difference.
Originally Posted By: Gary Reecher This post was automatically imported from our archived forum.
By chance is this a heat pump system? Could be that you are measuring the temp when the outdoor unit is in defrost mode and for some reason the air handler electric strips or furnace if this a duel fuel unit is not coming during defrost mode.
