Originally Posted By: Scott Wilson
Sure!
What you’ve got here is a pedestal mounted service.
The Power Company’s underground cable (I’ve never heard of or seen an “underground main bus feed”) comes up in the rear section. If you’ll look, the cover on the lower rear is removeable, although the mobile home has been placed too close to the pedestal to access the utility area.
The front section can be used for customer conduits.
I don’t know the use of the flex, but can tell you that it’s about 2", not 4".
A 4" would be too large in diameter to even fit in the panel.
The bad part of this installation is that the corrosion around the bottom will eventually cause this thing to flop and fall right over, or be supported by the utility's cable
