Main Disconnect
(Tucker J. Petterson) #1
Hello all. I was at a home today and could not see a main disconnect… However I did notice this one 60 Amp breaker that loops back and is soldered to the bus bar. Does this act as a main disconnect?
(Bradley K. Toye, CMI) #2
Google “Split bus panel”. The top six breakers make up the service disconnect.
(David Wigger, CMI) #3
Split buss panel.
When all the 220 v breakers at the top of the panel are off, the panel is ‘dead’.
The bottom 220v breaker on the left bank shuts off the lower section of 110v breakers.
(Tucker J. Petterson) #4
Thanks! I have seen split bus panels before but they were a little more obvious where the split was. I appreciate you taking a look.
(Stephen W. Stanczyk, WA License #221) #5
You mean 240v and 120v, right? :wink:
(Robert Meier) #6
:cool: A good habit to get used to.
