Main water shutoffs
Hello, all!
I was hoping to get some tips on locating main water shutoffs. I am finding them in the crawlspaces regularly. But I feel like I am wasting a lot of time crawling around. This last one happened to be buried by mulch in the front yard(thanks to a kind neighbor for the info), not in the crawlspace I just took 3 extra laps around trying to locate. Anyway, I think I have a couple questions. Answer as many as you’d like.
1. What are your methods for finding it quickly? Finding a line from the water meter has been successful. But it’s flawed!
  1. What do you do if you can’t find it? I got lucky today. But I expect it won’t always be this way! Do you simply write ‘unable to locate main water shutoff’?
    Anything helps! Thanks.
Don’t be afraid to say, in essence, “I could not find it, but you should figure that out as it is important as a homeowner to know where it is.” In my area, there is almost always guaranteed to be one inside the water meter enclosure at the street if they are on public water.
In my area, if you find the water meter, you have found the main shut-off 99% of the time. There will usually be a valve on each side of the meter. I’m in the land of basements, so 99% of our water meters are located in the basement and typically accessible.
State in the report that the main water shut-off valve and water meter were not located.
Like Ryan, I am in basement / God’s Country. In older homes, it’s on the street side of the basement. Coner lots have two options. On newer homes, it’s in the center of the basement.
If it’s a house on a hitch, there is typically a sticker on the exterior of the home showing where it is. Normally this is under the water heater.
Yeah, I always try to find it but default to “at the meter” when I can’t. That truly is the only place many times.
I’ve joked many times about how water shutoffs are a sign of how the world used to be a tougher place. More times than I can count I’ll enter a crawl space on the back of an old 1950s ranch house, fight past drain/waste pipes as a I work my way around and finally get to the front wall where the water service enters….. and there’s the shutoff. Conveniently located on the opposite side of the crawl space from the entry, over ducting, insulation, dead animals, insulation and everything else typically found in crawl spaces. Yep, need to shut off the water? No problem, just jump under the house real quick…lol.
Dowsing rods may help locating a water line, which can aid in finding the shut-off. It works on other utilities too.
Is it as accurate as using an aluminum ladder to find the overhead service?
Yes very accurate. Without the adverse side effects.
Follow the pipes. It is typically within a few feet of where the main enters the home. Most often in my area, the pressure regulator is adjacent to the shut-off so that big bell housing is fairly visible.
If I am having problems finding the valve, I start from the cold side of the water heater and work my way back.
You have just described 90% of the homes in my area including my own. I thought about having my plumber change the location of the shut off since it is, like you said, in the crawlspace where you have to low crawl all the way to the front side of the house.
I use one of these at the meter. Avoid the crawl unless absolutely necessary. :slight_smile:
The meters in my area have all been replaced with the digital meters so the old water key does not work in that instance.I do have one and keep it in my vehicle just in case.
Wow, that is unexpected. So what happens if your main springs a leak between the meter and the shut-off in the crawl?
They dig up and remove the curb stop when they upgrade to smart meters?
Gotta call the city to come out and shut it off for me. Just recently had to do this because a tree company, after being told where the water meter was and not to drive over it did just that and disconnected my water meter and flooded my yard. Although I am in Atlanta, I’m in a very small 2 mi.² suburb called Hapeville so the city comes out within minutes. Either way it’s a hassle.
FYI, I have been inspecting n Atlanta, and Hapeville for a very long time. There should be a shut-off. I have never ever seen one missing ever. I would double check, triple check before spending any energy in relocating the one in the crawl. Relocating a shut-off is not always sensible because the shut-off is close to where the water main enters the crawl for a reason.
The damaged meter does not indicate a missing shut-off….it indicates damage that caused a leak.
There is a shut off under the home, but the traditional water key does not work to shut off the water at the meter.
So what does? A home owner cannot shut-off the water to their own home on the residential side? Very unusual.
Hey, I think I reached out to you when I first got my Cpi for mentorship!!
