system
(system)
June 27, 2004, 12:00am
Originally Posted By: kmcmahon This post was automatically imported from our archived forum.
Is there a maximum # of turns in a waste pipe? This one appears to do a 360 degree turn.
--Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
2
Originally Posted By: dcarroll This post was automatically imported from our archived forum.
Looked in Code Check, and the only thing I can see there is the possibility of needing a cleanout or two.
system
(system)
3
The distance was so short, I didn’t even think about cleanouts…I just knew it didn’t look right.
Thanks!
–Wisconsin Home Inspection, ABC Home Inspection LLC
system
(system)
4
Originally Posted By: dbowers This post was automatically imported from our archived forum.
When you start thinking about the maximum number of elbows - look in the Original Codecheck and view the graphic of a venting arrangement under a kitchen island sink for Bow Vents - then - compare elbows.
