Measuring roof decking materials
I know this is a bit of a silly question/statement, but the picture shows a ruler to measure the thickness of the roof decking materials. I can see this happening if it were 5/8 plywood or OSB, but if it’s 1.5" T&G, I don’t believe you’re going to be able to get that ruler between the sheets. Am I over thinking this?
not really. can you see how thick it is from the eaves? i know it’s covered by drip edge (should be anyway) but it should be relatively easy to see how thick it is. (probably) a stupid question, but doesn’t the roof deck require spacing between the sheets, aka plywood clips? now you’ve sent me down a rabbit hole…hope it doesn’t go too far.
You should be able to see the thickness at plumbing stack and vents, if they have any.
Hahahaha. Sorry for the rabbit hole. My thought was…..if it’s tongue and groove, there are no clips, so it would be impossible to push a ruler between the sheets. But like others have said, I’m sure there are other points of the roof that I can see thickness from.
Probably. But most of us get curious about stuff like this. I’ve never measured roof decking, but I’ve known what I was walking on just by how it felt. I’ve never seen tongue and groove on a roof, but maybe it’s done in other places.
No. One obvious reason is that if you are spacing 1/8" on the ends that you center on a 1 1/2" wide edge of a truss, you are off the edge of the truss after 6 sheets.
you don’t put the clips where they butt at the sides, just between the rows. they never go over the top, and if they do, it’s (uaually) a very easy thing to snap a line and cut for the ridge vent. there are only a few roofs i’ve seen without them and i always call them out if they’re not there.
don’t be. i actually forgot about it and never did go down. it was a day yesterday. have a great weekend.
Ridge vents or clips?
Most modern roof sheathing manufacturers do require spacing and sheets are sized for spacing.
In my area T&G is rearely (I’ve never seen it) used for roof sheathing, very commonly used for floor sheathing. Roof sheathing thickness requirements in Florida changed in the 2020 FBC and according to the 2026 FBC DRAFT will continue. There are other threads about this topic too:
Good point, although in my experience back when I was a carpenter, we never spaced them and we still struggled with keeping 24" centers on a large roof.
Regarding clips, when 5/16" plywood was allowed, clips were required, but our local inspectors never required clips on 7/16" or thicker sheathing. Watching the new guy walk on 5/16" can be entertaining when he steps on a joint halfway between the trusses.
both, but i was referring to clips. they should both be there unless other ventillation is used.
we never spaced them on the sides either but i don’t recall ever having an issue hitting the trusses when they were on the right layout. the trusses usually moved enought to get them on layout unless someone nailed it wrong on a sheet before that one. the longest span on a roof i’ve ever worked was just shy of 200 ft on an apartement building. but it was also in '98 so there may have been issues i don’t recall. i know it was a relief getting the roof on for that job.
