Metal Gutter slope
Originally Posted By: Kevin Blackwell
I am trying to find what is the required slope for metal gutter sloping
the answer I am looking for is a format like 1"per 12’ etc…
Thx Kevin from Houston,Texas
Originally Posted By: dvalley
Hello Kevin,
You mean aluminum gutters, right?
To ensure that gutters drain properly, make certain they slope (1/2 inch for every 10 feet) toward a downspout. For gutter runs longer than 40 feet, it?s best to pitch the gutter down from the middle to a downspout at each end. Or you can slope the gutters down from each end toward a single downspout placed in the middle of the run. Determine what works best for the house?s orientation.
![](upload://qFmolxc9QZ5xuDZTe21e7GGQAta.gif)
David Valley
MAB Member
http://www.masscertified.com
Hi David,
I am preparing for the pro. inspector.exam and the question was quote
what is the proper slope for metal gutters unquote.
Thanks for your reply I know the question was not clear but your answer
did help.
Kevin form Houston, Texas
Originally Posted By: jpeck
I don’t believe there is an “proper” slope.
I think everyone has their own ideas on what works and what does not work. Down here, I find a lot of 'flat' gutters which drain well, and we are talking 40', 50' and longer gutters. As long as it is not reverse sloped it drains well.
Not until you get leaves in it does a problem come up, and the solution is not sloping the gutter but keeping the leaves out.
Thus, I would say the "proper" slope for a gutter is 'as long as it is NOT reverse sloped'.
Jerry Peck
South Florida
