Metal roof leaking
I’m a new inspector and recently received a lead through yelp. The home owner wanted someone that was certified in roof inspections and to write him an estimate, so referred him to a roofing contractor. He sent me a bunch of photos. There is obvious water penetration coming from the roof. I think it’s the fasteners and maybe missing flashing. I would like to learn how to inspect metal roofs better. Any advice would be helpful. Thank you.
Shed looks unfinished inside, shouldn’t be too hard to follow it back to the source. Check that closure strip along the whole length of the peak too.
Here’s a good video that shows the install process of what you have (Standing seam metal roof) Lots of ads though.
Good to know how it’s installed and can help you with inspecting and terminology.
I see exposed fasteners and wide ribs so this is not a standing seam roof. It is a thinner gage cheaper material than you will find on a standing seam roof.
You have no underlayment and no sheathing so this is like storage-shed level quality construction. Find the water puddles on the floor and look straight up. There are your leaks.
Wind driven rain leaks or normal rain leaks??
Fasteners are #1 for exposed fastener roofs. Did they utilize proper fasteners everywhere, with the rubber washer? Out of place/loose fasteners, over/under tightened fasteners, damaged/hardened rubber washers, expanded holes in the steel. Then look at the seams between the panels; is a gasket present? Ridge cobra vent material at ridge, if present. Or closer strips missing or out of place as alternative to cobra vent at ridge. Closer strips also present/absent at eave. Gable end flashing, present or not.
Get on line and review several “exposed screw metal roof installation guides.”
There’s an InterNACHI class for that.
I think PBR Panel but could be mistaken.
Metal roof systems generally have to install a water barrier membrane under the panels and around penetrations.
Metal roofs “sweat” (develop condensation) when warm, humid air inside a building rises and contacts the cold underside of the metal panels.
Prevent metal roof condensation (sweating) by creating a barrier between warm, moist interior air and the cold metal surface.
Just my 2 cents.
Look at the openings on the raked end. Then look at the metal supporting channels. Wind driven rain can enter the support channel and move downstream until the bulk water pools and spills over.
I hope that’s just light shining up through the corner trim. But you may be right, because I don’t see the shadows I would expect from the corner trim laying on the sidewall ridges.
For the OP, is there corner roof trim installed at the rake edges? Would look similar to below..
Thank you for the feedback. I haven’t been to the site. The owner sent me those photos through. Yelp. I reached out to him and I believe he has found a roofing contractor to come out. If I get more photos or get to go there. I’ll post what I find.
Anytime you put hundreds of holes in a metal roof you can expect a leak. Finding it would be easier without insulation, but another leak is to be expected.
IMO, exposed fastener roofs suck. I see a lot of them when I’m in Maui and they all leak. Even the best fasteners seem to start leaking by 10-15 years. Then comes the real fun - getting on the roof to replace or seal them without causing damage. Standing seam metal is just so much more reliable.
As for this specific instance, I agree to consider condensation as a potential for what looks like leaks.
