This is the day for a lot of questions, I was just trying to verify if the power cord for this microwave is energized, as the unit showed no signs of life, with my non-contact tester and I pulled my tester out and it immediately starts going off nowhere near any power.
It’s this microwave energized? I’ve tried touching the microwave with the back of my hand and getting nothing, yes I know that wasn’t the best idea, but anytime I go near the microwave with my tester it goes crazy. I must admit I’ve never put a tester like this near the microwave? I tried mine at home and it didn’t respond this way.
I have run into this before. I have been using these testers for 20+ years. Yes, they can false positive. The issue is that usually when it’s false, it’s a very specific location and you have to be quite near.
When they fire off from any kind of distance, chances are something is energized.
Get your actual meter out, clamp to something grounded and test for AC.
My most recent occurrence of this was a ladder into an attic. NCV fired off from 12 inches away.
I tested the ladder with my meter and was showing 60 volts. Odd level of voltages, but why was it energized? Turns out the doofus that installed the ladder drove a lag bolt through the truss right into the wiring for the light at the top of the ladder. Since there was no direct ground path, nothing tripped, nothing overloaded. I have no way of knowing when that ladder was installed, but it could have been like that from day one.
