Originally Posted By: wwarner
Anyone know what minimum length of fuel supply drip leg should be on propane service?
Bill
It's only Rock 'n Roll.... but I like it!
Bill
Originally Posted By: dvalley
David Valley
MAB Member
http://www.masscertified.com
Bill
Bill
Originally Posted By: jpeck
Jerry Peck
South Florida
Bill
Originally Posted By: wrobedeau
Quote: |
SECTION 408 (IFGC)
DRIPS AND SLOPED PIPING 408.1 Slopes. Piping for other than dry gas conditions shall be sloped not less than 1/4 inch in 15 feet (6.3 mm in 4572 mm) to prevent traps. 408.2 Drips. Where wet gas exists, a drip shall be provided at any point in the line of pipe where condensate could collect. A drip shall also be provided at the outlet of the meter and shall be installed so as to constitute a trap wherein an accumulation of condensate will shut off the flow of gas before the condensate will run back into the meter. 408.3 Location of drips. Drips shall be provided with ready access to permit cleaning or emptying. A drip shall not be located where the condensate is subject to freezing. 408.4 Sediment trap. Where a sediment trap is not incorporated as part of the gas utilization equipment, a sediment trap shall be installed downstream of the equipment shutoff valve as close to the inlet of the equipment as practical. The sediment trap shall be either a tee fitting with a capped nipple in the bottom opening of the run of the tee or other device approved as an effective sediment trap. Illuminating appliances, ranges, clothes dryers and outdoor grills need not be so equipped. |
Originally Posted By: cradan
Chris
http://www.inspect4me.com
Chicago Illinois Home Inspections
wrobedeau wrote: |
I am not certain what your point is. The posting is from the the International Fuel Gas Code and is a generic chapter under piping. If you read the code it covers steel, copper and plastic piping.
Bill Robedeau |
Jerry Peck
South Florida
Bill
Originally Posted By: jrabanus
Quote: |
in HVAC I have never even heard of it. |
Bill
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: cbuell
Quote: |
Black Steel Pipe
When steel pipe is forged, a black oxide scale forms on its surface to give it the finish we see on this type of pipe. Because steel is subject to rust and corrosion, the factory also coats it with protective oil. It is used for gas distribution inside and outside the house, and for hot water circulation in boiler systems. It is not used for potable water, or for drain waste, or vent lines. It is sold in standard 21-foot lengths TBE. Black pipe is cut and threaded to fit the job. Fittings for this type of pipe are of black malleable (soft) cast iron. |
It is easier to change direction than it is to forget where one has been.
IRC Part VI - Fuel Gas ... wrote: |
G2413.4.1 Cast iron
Cast-iron pipe shall not be used |
Robert O'Connor, PE
Eagle Engineering ?
