Minimum Vent Pipe Size?
Originally Posted By: bsmith
What is the minimum size for the vent stack piping ?
Bill Smith
www.SmithHomeInspection.com
“The difference between stupidity and genius is that genius has its limits.” A. Einstien
Originally Posted By: jbehling
One size larger then required waste pipe (min 1.5", IRC 3108.3)
Originally Posted By: dvalley
The waste stack shall be sized based on total discharge to the stack and the discharge within a branch interval. The waste stack shall be the same size throughout the length of the waste stack.
1 ?? can receive 2 fixtures max. total discharge
2? can receive 4 fixtures max. total discharge
2 ? ?can receive 8 fixtures max. total discharge
3? can receive 24 fixtures max. total discharge
4" can receive 50 fixtures max. total discharge
David Valley
MAB Member
http://www.masscertified.com
Excellent, thanks you both.
Bill Smith
