I am inspecting an older mobile home next week, any tips/suggestions for things to be aware of or look for?
Aluminum wiring and polybutylene plumbing
Additional to what Brian said:
Sagging belly wrap indicating leak area, weak/spongy floor under windows and around doors indicating leakage caulk/sealant missing or cracked on the outside, roof needing maintenance/repair/replace, service disconnect on pole outside, remote distribution panel on inside, very weak roof framing, hidden (usually behind wall panel screwed shut in hall or bedroom or accessed from exterior door or panel.) water heater, unprotected pipes in crawl, missing belly wrap indicating previous work area, lack of gfci receptacles where needed for safety, trailer not secured to ground, etc , etc , etc.
Tie downs
