When applying moisture barrier for stucco and or faux stone how should the moisture barrier be installed?
Correctly of course Carl
Pic is too small BTW
Is this one bigger?
here’s a
hint III Products 5
II Products
1.
Does not say anything about the use of 1.75 lath that a lot of mfgrs. are pumping out and marking as 2.5.
Is this one bigger?
Faux Moisture Barrier
Is this one bigger?
Try this site http://www.eifscouncil.org/english/home.htm
and read this-
Let’s try this;
http://www.fortifiber.com/pdf/install_guides/IG_jumbo_tex.pdf
http://www.fortifiber.com/jumbo_tex.html#
Hope this helps
Marcel :)![]()
You guys are GREAT!
http://i280.photobucket.com/albums/kk164/cab1961/th_1layergradedpaper.jpg](http://www.nachi.org/forum/[URL=http://i280.photobucket.com/albums/kk164/cab1961/1layergradedpaper.jpg][IMG]http://i280.photobucket.com/albums/kk164/cab1961/th_1layergradedpaper.jpg[/IMG][/URL])](http://i280.photobucket.com/albums/kk164/cab1961/1layergradedpaper.jpg)
<center>
<img src=“http://i280.photobucket.com/albums/kk164/cab1961/1layergradedpaper3.jpg” alt=“Photobucket - Video and Image Hosting”><br><br>
</center>
<center>
<a href=“http://i280.photobucket.com/albums/kk164/cab1961/1layergradedpaper3.jpg” target="_blank">
<img src=“http://i280.photobucket.com/albums/kk164/cab1961/th_1layergradedpaper3.jpg”></a>
</center>
