I need to buy my first moisture meter.
There are so many to pick from.
Any suggestions? Under $100.00
Roy Drangstveit
Roy Drangstveit
There are no reliable instruments upon which a legitimate home inspector could use to provide reliably accurate information in a home inspection report regarding a defect relating to moisture for less than $100…other than his flashlight.
If you plan to compete with the big boys, Roy, you need to invest in your education, equipment and marketing.
Agreed. Your looking at about 300 - 500 Roy.
Extech makes an excellent pin meter for around $100 (model MO210)
You have a link?
Protimeter (mfg by GE) make a nice mini meter for about $175.00
This one uses a regular 9v battery.
Had this one over five years and it works great.
https://ssl.biggiweb.com/testersandtools/AEMC-CA847-Moisture-Meter.php
No ,do you have Google?
Just happen to own one and they are at Grainger.
:mrgreen:I knew you were busy Bob, so I gave it to him.
Moisture Meters are basically Ohmmeters.
That is a good article Brian.
My Lignometer is well over 25 years old. Pin. Compared it with a digital model the boss’s brother bought for $200 and came up with the same reading.
I finally bought a moisture meter this year. Went pinless and inexpensive.
I hardly ever use it, for the most part if there is moisture I can see it.
Doug Edwards posted a link to an inexpensive moisture meter once or twice, if you ask him nice I am sure he will post it again.
I see crappy, incomplete, pictures from ir guys all the time telling me they can not see moisture stains John, nothing new.
