The article was on moisture meters…
There are 2 types of meters … pin and search mode meters. The pin type will penetrate into the surface where as the search mode just skims the surface of the possibly contaminated areas.
There are different types of surfaces that each can be more beneficial to… the pin meter uses an electrical conductivity for its readings and the pinless or search mode systems use electromagnetic waves.
False readings could be an issue if there are metal components in areas.
In summary the type of meter you use can depend on the surface and situation that you are in. False readings can be detected with proper evaluation of the areas.
Adam Sherako
mrsa2172
