Mold Information
Robert O’Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
Originally Posted By: dplummer
Robert; Thanks for sharing. It’s a great site! DOUG
Originally Posted By: Nick Gromicko
MARCH 2004 Volume 2 | Issue 3
HELLO NACHI!
I hope that you are doing well. In this issue, Dr. Harriet Burge answers some questions about Crawl spaces and mold.
Please let us know if you have any questions or if we may be able to help in any way. If you have other topics you?d like us to discuss, please let us know at: info@emlab.com.
With warmest wishes,
Dave Gallup
Chairman
ARE CRAWL SPACES ALWAYS A PROBLEM WITH RESPECT TO MOLD?
Mold can always be recovered from crawlspaces. Many are dirt-floored, and the soil is filled with fungi and bacteria. The pleasant odor associated with freshly turned soil is the result of volatile organic compounds released from these normal soil components. These odors could penetrate into the occupied space, but cannot be considered a significant health threat. As long as the soil and the crawl space surfaces remain dry, however, mold contamination should not be a problem.
ARE CRAWL SPACE MOLDS DIFFERENT FROM THOSE THAT GROW ON
SURFACES IN OCCUPIED SPACES?
The usual damp surface molds (species of Penicillium and Aspergillus, among others) can be common on crawl space surfaces. In addition, persistently wet crawl spaces can support the growth of wood rotting fungi that not only destroy the wood, but may produce fruiting bodies that release billions of potentially allergenic spores.
UNDER WHAT CONDITIONS DO CRAWL SPACES BECOME ?MOLDY??
Any time water enters a crawl space, mold can become a problem. Some crawl spaces are penetrated by ground water. The soil then becomes wet enough to allow amplification of some of the molds, leading to production of volatile organic compounds that cause unusual odors. Wet soil can also lead to condensation on other surfaces within the crawl space. Another source for water that can cause condensation is outdoor ventilation air. In the summer the crawl space is generally cooler than the outdoors. When humid outdoor air enters a crawl space, condensation is almost inevitable.
IF THE MOLD IS ONLY IN THE CRAWL SPACE, WHY DO WE HAVE TO WORRY ABOUT IT?
Other than the potential for wood rotting, you may not need to worry about the mold if the ventilation patterns in the house are such that air consistently moves from the house into the crawl space. If this is not the case, then odors and spores will penetrate the occupied space whenever air from the crawl space enters the home.
DOES VENTILATION OF THE CRAWL SPACE HELP PREVENT MOLD?
Crawl space ventilation is often recommended to reduce radon levels in crawl spaces. If the ventilation air is dryer than the air in the crawl space (i.e., if entering the crawl space is not going to cause the water in the ventilation air to condense on surfaces) then ventilation can be effective. Thus in desert environments, ventilation can be a useful method to keep a crawl space warm and dry. However, in hot humid climates, ventilation of a crawl space with untreated outdoor air is likely to make the problem worse.
CAN CRAWL SPACES BE BUILT (OR REMEDIATED) SO THAT THEY DO NOT BECOME ?MOLDY??
The key to preventing mold in crawl spaces is to make absolutely sure that no water will enter that can either lead to wetting of the soil or to condensation on surfaces. If this is not possible, then crawl spaces should be avoided. For existing crawl spaces, sometimes changing ventilation patterns can help remove water. If all the water is coming from the soil, the crawl space can be sealed so that no soil is exposed within the space. This should prevent condensation on surfaces, but mold will still grow beneath the sealant. If the sealant is not impermeable to volatiles, odors may remain a problem.
