“Mono” means one; “lithic” means composed of stone. A monolith slab is a type of “slab-on grade”, as Jeffrey mentioned, where the footing and the slab are poured as one continuous piece.
It’s a term used in IRC. You’re in middle Tennessee, right? I’d be willing to bet that they pour monolithic slabs somewhere in middle Tennessee. What’s your background?
Monolithic slab is one that is made in a single continuous pour and includes the floor and the foundation. By comparison, basement floors are usually poured after the foundation. The floor is independent of the foundation.
Or, bearing slabs have a separately poured footing & a bearing wall of either cast in place concrete or more likely CMU, with the cast in place concrete slab poured on top of the bearing wall. Then you have floating too, like a basement floor, etc.
"You’re looking at a monolithic slab – basically one giant, singular pour of concrete that serves as both the floor and the foundation. It wraps a beefy thickened edge (called a ‘footer’) around the perimeter, right under all the load-bearing exterior walls. Some designs even throw in extra thickened sections inside the house for interior walls, depending on how fancy the builder was feeling that day.
This is the go-to move in states that looked at basements, shrugged, and said, ‘Nah, too much work.’ Frost lines? We don’t know her. Freezing ground? Just pour thicker concrete and call it a day."
Monolithic slabs are poor so they need financial assistance/welfare. Since they sit around all day they have a large girth around their load bearing asses. They never see the sun on the exterior. You see these in States that do not have video game rooms in the lowest level of the house. Of course it all depends on the design.
Hmm maybe if I have a few more Jack & Cokes I’ll have a corrected translation?
