MultiMeter Training- Ideal
Howdy,
Figured some of you might like to read this article on how to use a MultiMeter from ideal.
http://www.idealindustries.com/pdf/tm/Basics%20of%20Digital%20Multimeters.pdf
Thanks, I will use it. I teach a class in residenrial heating, next week, the electrical stuff.
As a side bar - do you use a multimeter with fused probes for protection?
Virtually every multimeter I have ever seen has an internal fuse.
That really only protects the amp scale anyway. The digitals are virtually impossible to blow up with anything we will see in a home on the other scales. Old analog meters could have the movement damaged on an overvolt and the resistors would fry if you put voltage on the resistance scale.
