First, I have an old 5’x12’ coal bin in the basement of the house yesterday with a 1/4" of coal dust on the floor and a few small piles. Is this a fire hazard?
Second, can this flex conduit from the meter be considered the GEC if the meter has a wire to the rod outside?
Third, the house had a HE furnace with half/half PVC and ABS flue. Would a glued joint between the two materials be disallowed in this flue like it is in a drain connection?
I would say yes to the coal–advise to clean it up as airborne particulates could ignite (low probability however)
I don’t think you can use the jacket of the conduit as the GEC but not 100% sure…
I would say No you can’t mix plastic vent pipes. In ontario the black pipe is no longer allowed on new HE installations past 2007–but regardless mixing plastic types is not a good idea.
Pvc and ABS should not be glued together in any application, I’ll let the code gurus comment on the other stuff, but I wouldn’t do the way it is shown.
From what I understand the transition glues are not allowed in plumbing connections, only mechanical splices, but I have never come across this on a HE vent so I don’t know if it applies the same. It’s amazing how something new always pops up.
I have been under the assumption that transition cement (usually a mint green in color) is allowed for all non pressure joints between PVC and ABS. So I am thinking it would be allowed on a HE exhaust.
Up here TSSA (governing body for all fuel burning and storage ) will not allow this transition. Any service work by a licensed tech to exhaust of older units with ABS must have all removed and replaced with PVC . Not worth a license to save a few bucks and if at any time a licensed tech came in to service the furnace on seeing this they would shut off the fuel supply and refuse fuel delivery or other service untill proper repairs were done.
