My $125 thermal master is all I need, change my mind
So I purchased a thermal master P1 over a year ago with the idea of buying something better once I could afford it. But it’s been going strong and has found a ton of things I would not have found without thermal. Is there any legit reason why to upgrade to anything more expensive? This thing has blown me away.
Add some pictures and we will see.
here are a few images I have use
They appear to be a bit fuzzy, blocky, or lacking resolution.
Also, the images may be showing fairly large/egregious anomalies, however better equipment excels at the more subtle (and more common) findings.
Show me something better? Edit :Just to clarify there isn’t any particular defects in these images these are just random photos taken with my thermal master P1
Probably not for the qualitative type work you have demonstrated.
Also, IR training will expose or educate you on the limitations of your equipment. All of the equipment has value, just be sure to use the right tool for the right job.
Where do you suggest training for that? I do understand that you could get something better for detailed work on certain things but what would a home inspector need that for?
Describe your images and the methods you used to verify
These images don’t show shit
Remove all of the natural and artificial light sources, and what do you have left?
Google Level 1 thermography certification
So you understand your equipment and can accurately interpret the data you have collected. If you consider such training useless, then realize you have nothing more than a flashlight in your hand. Without interpretation skills, you are not serving your clients well, IMO.
So the main thing is thermal anomalys Missing insulation is fairly obvious, if I see anything that looks like a possible water leak I get my moisture meter and verify moisture content. I’ve found HVAC suction lines in walls with missing/damage insulation on them, (could be a problem with condensation from those lines in the wall) , found a lot of water leaks inside walls and underneath upstairs bathroom, missing insulation, termites , wood rot. I’m asking legitimately if there a reason for something better. and I’m always up for more training if it makes me a better inspector but getting training on using thermal for diagnostics on PC control board seems like it might not translate to my home inspection career :joy:
I can’t see any difference with the light on or off in the house except for heat from light fixtures.
Sometimes, sometimes not. For me, I didn’t know what I didn’t know until I became certified.
As I stated, for general easy qualitative work with little consequence, you will likely get away with the minimal understanding of what you are looking at.
Seriously though, it is hard to convince someone who comes at it with the attitude “prove me wrong.” I am not in that business. But if you would like, I could share with you some of the benefits.
I didn’t mean to come across as prove me wrong I’m legitimately trying to learn man. That’s why I said change my mind. :joy: Everything gotta be super serious and everyone going to fight to the death on both sides. Some to justify an expensive purchase and some to be cheap.. I’m just wanting to do the best by my clients man
I think ever home inspector should have some type thermal though that’s for sure
Awesome.
Check this out. There is money to be made in the thermal imaging business, but also money to be lost if you screw up.
Your credentials will keep you out of hot water.
You are much less likely to report an anomaly incorrectly.
Better ability to define anomalies and justify further action.
Better understand limitations, especially conditions which will improve or impede your evaluation.
I would not buy an expensive camera without the training 1st. From there, you will be able to define your path. You will be a better inspector and your service to your client will increase exponentially as your knowledge grows.
Be the most knowledgeable person in the room. It will pay off.
Not particularly, unless you want to get into more exhaustive and technical thermal imaging jobs.
Using the $125 imager is fine for doing typical home inspection things like looking for large areas of missing insulation or significant water leaks. As long as you don’t hold yourself out as a “professional technical thermographer,” using the cheaper tool is better than using nothing. Just make sure to verify your results when needed with other tools like moisture meters, etc.
I don’t change any extra for using my thermal camera (I legitimately don’t want to do an inspection without it)
So far it’s made me a hero on several inspections.
But I’m always learning and improving because I love what I do. So any criticism is welcome
I use mine on every inspection as well (Flir E4 hacked to be an E8) and don’t charge anything extra. I have also been hired to specifically look for missing insulation in homes. It is a suitable tool to do that, and even your $125 model can do that just fine for the most part.
Yep, if you understand what conditions should be present to do that.
Wait until someone burst your bubble about missing wall insulation when in fact it was reflective heat. Or conditions were not conducive so you issue a clean bill of health.
I think there is a battle between IR snobs and everyday users. I do not know enough to be a snob. I am a simple Level 1, but I do know enough not to get into trouble.
