I could give you at least two reasons the temperature anomaly may be present. But…
Meanwhile, the BS is getting thick…
How does wood rot create a big blue spot (thermal anomaly) on the ceiling?
I’m sure you can. I do need to learn more. Sometimes I guess it has something to do with airflow in the home causing a cooler spot or something in-between the floor space on 2 stories? Those are things I would really like to learn honestly.
As far as how does wood rot show up on a ceiling as a blue spot? I’m not sure when I did the inspection it really made me feel stupid because my moisture meter wasn’t showing anything? And no water stain.
I figured after they told me that it must have been wet still at the time of inspection and my moisture meter was working right so I bought a new one.
Anyways I’m learning everyday and always will be.
The only thing that makes me believe that story is that the crappy thermal camera you use is followed up by a crappy moisture meter.
Get the training. Get the right tools. Do this before you charge anyone else.
Sorry I don’t know how to use the forum very well. This is the image that I use when I was talking about not knowing so called for further evaluation. This is literally all I had.
I’m beginning to think I can’t have a normal conversation on the Internet without making at least 25 people mad or have a stroke ![]()
this was supposed to be a conversation on what I can do to improve my terminal game and if it’s worth it. An now my integrity and knowledge have been questioned and not having enough training or the right tools for my job and I need a $2500 training for thermal and I don’t even know how much on tools (because nobody has suggested anything better yet)before I even charge anyone else for an inspection? Man and here I was thinking I was the best ![]()
Maybe I’ll make it someday…
I am going to hop on that InterNACHI thermal class though. Thanks
This is great. I highly recommend it. The part 2 video starting at 1:50 in particular!
Seriously a great course. Definitely worth checking out or revisiting if you haven’t done it in awhile.
Infrared Certified® Thermography Inspection Course - InterNACHI® is the latest one
If that is what you are doing, you don’t have to do that here. Just be real.
If you get the training, you will know what tools to buy for what you will do.
As Brian said, training first, then tools, then charge for the service.
That image should have you thinking, first and foremost.
Is it under a water source (bath, laundry, HVAC, attic, roof/wall intersection)?
Does it have elevated levels on a moisture meter?
Was it recently repaired or changed?
Is there an A/C duct nearby (air can “change” the color on the device’s display)?
You haven’t collected enough data to decide if calling for evaluation is even on the table.
So I finished the InterNACHI course that Brian recommended me last night. And I know I need a thermal camera and moisturizer meter. Still don’t have the answer on what brand or even a price point to start with. I’ll do the updated version of that course soon and see what I get from that I suppose.
I can’t afford a $2500 class on thermal right now.
I completely agree. I’ve started my inspection career with an AHIT class (Texas requires at least 194 hours before you can even get your license). Then I’ve joined InterNACHI and studied a ton with them. My original post here said I bought this tool with the intention of upgrading but it has done everything I’ve needed it to do and I don’t feel like it’s inadequate for home inspections.
But I’ve never owned a flir ( have use another inspectors flir , don’t know which model. The one that plugged into your phone). And another inspectors thermal master Thor. but from using those briefly I couldn’t tell that they did anything better for what we were using them for to justify me upgrading.
So I’m legitimately asking for advice on tools.
I’m using as a tool during home inspections not changing extra for it and I don’t offer any kind of thermography or energy audits services.
Ok so I knew it was under a upstairs bathroom. I did get my ladder and check it with a moisture meter. ( A Klein from Home Depot) Didn’t show any on my moisture meter. Look upstairs and toilet was tight to the floor, ran hot water in the shower for several minutes but the spot stayed blue and didn’t get any larger. So I showed my client the spot and told them it really looked like moisture spot but my moisture meter didn’t show anything and he , the realtor, and his brother in law spent awhile looking over that bathroom and running water and never could narrow down the cause. So I recommend further evaluation and the got the sellers to get someone to look at it. the feedback I got was they cut into the ceiling and found wood rot. (I didn’t get to see it with my own eyes so don’t know what that means exactly or how bad it was) And the realtor thanked me for finding it.
Obviously you want to know what you’re looking at with your thermal camera, air duct, dryer vents, waterlines in walls, heat reflecting from windows, ac vents blowing on walls or ceilings, wet paint from someone painting right before or during inspection, ambient temperature inside and outside the house and a ton of other things factor into using a thermal camera.
Anyways this has been quite the rabbit trail so far ![]()
Is there any recommendations on upgrading what I have and if so why?
And I’m up for more training always but I’m going to have to save up to become level one thermography . But I’m working on the latest InterNACHI thermal course and have already finished the one from 2009 that was recommended to me. I’m sure a lot has changed since then.
Wood rot doesn’t happen overnight, so if it was rot and wet on the day of inspection, it MUST have been leaking for a long time, and they just made the repair when it was discovered, they were “found out” for not repairing it and immediately had repairs made… OR… they were lied to!! Did they hire you to return to verify the issue was corrected?
Exactly. I don’t know what it looked like because they didn’t have me come look at it when they opened it and didn’t send pictures. (Wish more people would just to satisfy my curiosity) They didn’t specify what previous repairs meant. All I know is from a follow up phone call with the buyers agent after all that was done.
My honest opinion. That drywall is not dry, based on your interview. The report’s observation is invalid, and you are dealing with an active moisture issue that requires physical investigation. Which you did in error.
You admitted your incompetence to the client, shrugged, and escalated the issue. Perhaps that was the right thing to do. But that doesn’t mean it was the right path for anomalies in general. In fact, you got lucky.
BTW, you likely missed the wet spot with your moisture meter. It can be difficult to pinpoint where to put the meter under natural light (vs IR). A few inches off and you miss. IMO, if the story is true and that joist was wet, I cannot find a reasonable explanation for the dry sheetrock other than user error. Klein makes reliable tools.
I agree. (Except for the shrugged part). Anomalies are just one clue and warrant further evaluation to see what is causing them. Maybe I’ll become competent enough one day to explain every single one I run across. Would a $5,000 thermal camera have made any difference in this situation? Probably not.
I’m sure if you were there with my cheap camera you would have done better for my clients.
That’s been awhile since that inspection and I’d like to think I’ve grown since then.
Is there any I can do or say now that makes you believe I’m not your typical idiot? ![]()
That’s what I’ve thought for years but I’m beginning to question a few I’ve bought from them. But that’s a entire nother can of worms ![]()
I never said that.
Back to reporting anomalies based solely on an infrared image. Consider this:
Does your inspection agreement or scope of work define that thermal anomalies will be reported without additional evidence? Does it define what areas will be scanned and the methodology? Have you conveyed the limitations of infrared and managed the client’s expectations?
In a home inspection, I use the camera like a flashlight to guide me to the next level of investigation. The only way I would do more would be if I sufficiently answered the questions above.
Hot tip. Before placing the moisture meter on a surface, test it on your skin…99% and its good to go. And, zero it out first if it has that option. Also, you will need multiple readings, not only where wet, but also the surrounding area to be used as a control measurement.
If the level 1 training is too expensive right now, I would suggest starting with Monroe’s CRT program. Honestly, it covers most of what you would need to know for applying thermal to home inspections. They also dive into the science and the cameras, answering your question of why would I need something other than a cheap camera.
