NACHI updates home inspector industry search engines.
Originally Posted By: gromicko
http://www.nachi.org/search-update-2005.htm
Nick Gromicko
Founder
dues=79cents/day.
I much prefer email to private messages.
Originally Posted By: loconnor
So if this sytem works the way explained, why would an inspector 47 miles away, ALWAYS show up in the #1 position for a major town 7 miles away from me? He’s only a few miles from a much larger town!??
Perhaps I should change my zip codes to cover bigger towns in more counties. So instead of a 60 mile radius, I develop a 120 mile radius. Yeah! That's the ticket!!
Larry
Western Michigan NACHI Chapter
http://www.w-michigan-nachi.org
"We confide in our strength
without boasting of it.
We respect that of others
without fearing it"
Thomas Jefferson
Originally Posted By: Chris Morrell
Larry,
The system is based on the 20 zip codes you supply. It doesn't matter where your physical office is (often an inspector's home)--it's where you work. If the inspector, who may live 47 miles away, has put your zip code in as one of his or her 20 zip codes, they'll come up as an exact match.
This has always been the case. The upgrade to the system now means that no one will always have the #1 spot. Each potential client will see a differently sorted list of inspectors.
Chris Morrell
Director of Information Technology
![](upload://aHHRF6Q977qgUfOWijTzEtYmY2G.html)
Originally Posted By: rzimmerman
However If someones IP remains the same, like most DSL or cable users they will always get the same list. OK for the random homeowner. But this says a Realtor will always see the same person on top of the list.
Hind sight is always 20/20 In the revision can it be a combination of IP and date. This would change the list each day for any given IP.
Still think it is a GREAT JOB ![icon_biggrin.gif](upload://iKNGSw3qcRIEmXySa8gItY6Gczg.gif)
Rob Z.
www.RZinspections.com
Forgive me Chris…
So, if I understand correctly; if I punch up the same zip code 3-4 times a day evry day, I'll always see the other HI in the #1 position. But if someone else enters the same zip code, they may see my name in the #1 position at different times. Correct?
Chris I know it can't be easy keeping track of all the web site changes and adding new programs. Do you ever get help when you need it?
Great job!
Larry
without fearing it"
Thomas Jefferson
Originally Posted By: chorne
I guess I don’t understand because every time that
I type in any zip in my area and type in 50 or so miles
the same order comes up every time
I have been a member for 3 or more years and some
new members (within 1 month or so) comes up
before me. That isn't right
Carla
Originally Posted By: aslimack
I’m with Carla. I see the same thing happening. The order is the same every time i type it in with the same names above mine every time. That isn’t right at all, but it explains why i don’t even get a wiff of anything off those sites.
Adam, A Plus
Robert,
Excellent point. I've just modified the results to take the day of the year into consideration. I've also modified the code to give preference to a "resident" in the case where two people serve the same zip code.
Chris Morrell
Carla/Adam,
The same list will come up for you all of today. Tomorrow you will get a different list. The next day you will get a different list, et cetera. You won't always be at the top, but you should be on the top just as much as everyone else. In the case of the zip code that your office is in, you will be at the top more often than others.
Chris Morrell
Originally Posted By: jfarsetta
There are three NACHI inspectors that reside in my zip code. I do not believe one of them is in business anymore. That leaves two. Other inspectors who do not reside in this area code come up WAY before I do. I was. like, 5th last night.
Also, the next zip code is much closer to me than that of another town. Yet, inspectors in that town come up first. Again, this is not how the search engine should work.
Joe Farsetta
Illigitimi Non Carborundum
"Dont let the bastards grind you down..."
Originally Posted By: kwilliams
Chris, not complaining, have got a lot
of work from this, but, just checked
20 mile and I came up first with my zip
but did not show up on any others
just info for you, quite satisfied with
the service
Member - MAB
http://www.nachi.org/convention2006.htm
