Nails observed in the attic ... New construction
Brand new 2 bedroom unit … observed some nails that with 2 inches or more in the attic.
No signs of water penetration on the inside of the unit … is this an issue to write up ?
That’s an unusual application for framing(?) nails. I see them frequently used for tie-down installation, but your photo is not consistent with that. Would be very unusual (and wrong) here for typical framing nails to be used for tile fasteners. In this area the hip/ridge caps would require weather blocking where the caps meet the field tiles. Not sure about your location, but there are no Product Approvals for Florida which indicate OSB is acceptable for concrete tile installations, also the TRI manual indicates plywood.
They cut the truss(es) when they installed the attic vent(s).
Thank You …
