Has anyone use Kenton Shepards Narrative Library with the HG companion 'Iphone"?
How well dose it work, would you recommend it?
It will definately help you get started, but you will need to modify/optimize the narratives for you. They are t perfect. As far as using with iPhone… The iPhone app isn’t ready for use on Inspectons, you might still loose your data. It’s been just about ready for a few years. I have found the surface pro to work very well.
