Narratives from the pros
I am starting to notice narratives are specific to the one writing them. Share some of your most recent narratives for beginners like myself to see and get a PROs perspective, post a picture along with your narrative. This i am hoping will be extremely helpful!
Is this a suitable narrative in your opinion?
At the time of the inspection, concerns were noted regarding the adhesion of motor joints at the roof vents associated with the plumbing system. Motor joints play a crucial role in ensuring a watertight seal, and any deficiencies in their adhesion can potentially lead to water intrusion. It is recommended to promptly address and rectify this issue to prevent potential water-related damages. Consulting with a qualified roofing professional is advisable to assess and address the adhesion concerns, ensuring the integrity of the plumbing vent system.
It sounds too mechanical to me.
Although our market does not have tile roofing to speak of, I might say:
Failure of sealant and potentially clogged vent pipe can cause water intrusion and inadequate ventilation for the plumbing drain system. Recommend correction by qualified roofing contractor.
I bet that can easily be reworded to cut the length in half and still get the same point across. Just reading through it, multiple unnecessary words and phrases jump out to me.
In addition, you never actually state what the “concerns” you observed actually are.
So a concern is unable to be used in a report. Observation should be in its place?
Ok thank you
You can use concern, but your narrative doesn’t say what the actual concern is, such as degraded sealant or whatever you are specifically referring to. It would be like taking a picture of a furnace and saying a concern was observed at the furnace and it needs to be fixed. You need to be more specific. What is the actual concern?
What is your actual concern with the adhesion of the mortar joints? Are they loose? Are they degraded? Are they missing? Were they done improperly? etc, etc, etc.
What the hell is a “Motor Joint”? That term is used multiple times.
Looks like another failed AI narrative!
Ok re write it lets here how you would right it thats the purpose of this post.
Glad you didn’t note them before you got there. I suppose the mouse in your pocket made the note too? :slight_smile:
You don’t need to use this at all.
Get to the point.
" A tile penetration at a plumbing vent is damaged. This should be evaluated and repaired by a qualified roofing professional familiar with this style of roof to prevent further water infiltration. "
At this point I would include pictures underneath and comment on that as well.
Ok thank you
Nah, I’ll PASS. I’ve offered enough in your original thread, and Bert’s post pretty well stated what you need to know.
Come back when you accept reality, and we’ll see.
Good luck.
Observation: Structure: Roof.
Sloped roof.
Roof covering: Clay barrel tiles.
Sloped roof Flashing:
Plumbing vent stack flange inappropriately fashioned at the top.
Plumbing vent stack base flashing seal damaged.
Recommend: A licensed roofing contractor: Repair, properly install the metal plumbing at the top, and seal the metal plumbing stack vent to clay barrel tiles.
Act upon any recommendations therein.
I see this in reports and have the same impression… “At the time of the inspection…” Well, when the hell else would it have been?
" At the time of the inspection (**Wordy and unnecessary)**concerns were noted regarding the adhesion of motor (sp) joints at the roof vents (They’re not roof vents, they’re plumbing vents located on the roof)associated with the plumbing system. Motor(sp) joints play a crucial role in ensuring a watertight seal, and any deficiencies in their adhesion can potentially lead to water intrusion. It is recommended to promptly address and rectify this issue to prevent potential water-related damages (water damages). Consulting with a qualified roofing professional is advisable to assess and address the adhesion concerns, ensuring the integrity of the plumbing vent system." (Recommend further examination by qualified roofing contractor and remedy per the contractor assessment"
Wordiness is distracting. Specificity is crucial. Even spelling is important. As professionals, we have to take the time to give our clients a quality product if the client is to have confidence in our findings.
Following up on this, the original poster would do well to read this book. https://www.axios.com/smart-brevity
The original narrative was 85 words. I stated it could easily be redone with half the words while still getting the point across (and actually I’d say getting it across better). I’m going to stay within the narrative you posted and not try to change it by correcting the information. I’m only going to rewrite/reformat what you posted.
My rewrite below is 39 words. Please note, this is still not a good narrative in my opinion, it is simply a rewrite of a bad narrative to at least get the word count down.
Concerns were noted at the plumbing vent penetrations on the roof. These concerns may cause water penetration into the building envelope, leading to damage. I recommend the concerns be addressed by a qualified roofing contractor as soon as possible.
Just saying…this ain’t “May”
As I said, it’s still a bad narrative. A bad narrative can’t be made good just by making it shorter, lol.
Well, I’m going to argue :stuck_out_tongue:
" at the plumbing vent penetrations on the roof, water is penetrating into the building envelope; that will lead to damage. the concerns must be addressed by a qualified roofing contractor as soon as possible
28 words.
