[ASKNACHI]This question was posted on AskNACHI.org by Fred Svader (from Youngstown, oh 44509). [/ASKNACHI]Subj: Re: MY FURNACE AND AIR CONDITIONER
Date: 4/17/2008 11:27:28 AM Eastern Standard Time
To: [email protected]
Sent from the Internet (Details)
Copy and ask at www.asknachi.org
Nick Gromicko
Founder, International Association of Certified Home Inspectors www.nachi.org
Founder, Master Inspector Certification Board, www.certifiedmasterinspector.org
Executive Director, International Association of Certified Indoor Air Consultants, www.iac2.org
Host, NACHI TV, www.nachi.tv
----- Original Message -----
To: undisclosed-recipients:
Sent: Thursday, April 17, 2008 9:24 AM
Subject: MY FURNACE AND AIR CONDITIONER
To: Nachi?
I NEED TO KNOW THE MODEL No. OF MY AIR CONDITIONER.
IT WAS INSTALLED JULY 1990, GOT IT FROM MAZZA HEATING AND AIR CONDITIONING.
IT’S 1 1/2 TON UNIT,
On a sheet which I believe came with the Air Conditioning unit;
The following is on top of the sheet
PARTS REPLACEMENT GUIDE
AIR COOLED STANDARD EFFICIENCY
SPLIT SYSTEM 1 1/2 THRU 3 1/2 TON
FOLLOWING IS ON THE BOTTOM on the same side OF THE SHEET
7701-074 REVISED: OCTOBER, 1988
SUPERSEDES: DECEMBER, 1986
On the other side it shows;
I BELIEVE OR HOPE THIS ONE IS MINE??
208/230,
DESCRIPTION, Mfg name, Mfg Mdl No, 1 -1/2 TON
compressor (w/o HTR) BRISTOL H20B153ABC 0024345414 means?
The 1-1/2 Ton unit appears to be the only model H20B153ABC made for that size?
I’m getting my unit ready for the summer and noticed the model number is no where
to be found. Should it be on the removable bottom panel, the larger one. If so it’s not there, or I’m unable to read it.
The following information came from the original motor AND where can I purchase it or an EQUAL TO motor to match what I need to replace it?
EMERSON MDL K55HXMMB-4296
HP- 1/10; VOLTS 220/230; Hz 60;
PH 1; RPM 825; AMP 1.0;
RPM 825; THEMALLY PROTECTED;
PART No. 343295 not sure of the last two numbers.
MFG. #K892; INS;CLASS b 40degres Cent.
AIR OVER FRAME 48Y
S/A LR4 7513 5.0 370 VAC
