The county this home resides in doesn’t have permit records that go back past the 90’s. The box has been painted over more than once and the sticker is effectively non existent at this point. Home was built in 1982. The disconnect panel is original to the home. If anyone can identify the brand of this disconnect by the design, I’d appreciate the help!
Do you have any photo’s of the interior with the dead front off?
I do not. There was no way to remove it without damaging it.
How so, there aren’t even any screws holding it on in the photo.
Curious, what will that information do for you?
So, the (exterior) panel is 40+ years old…
Sounds like a couple of good reasons to recommend it be replaced!
So how will an electrical contractor gain entry to evaluate and/or make repairs?
My guess is corrosion/paint. It was stuck in place and I didn’t want to damage it
This information is for the Citizens 4 Point form which asks for the brand of the panel. I get your points but I’m not a contractor. I’m an inspector. Its my understanding that I shouldn’t engage in an act that could cause damage to myself or the property. Yes, the panel should likely be replaced.
Thank you sir!
