Need some help double tap?
Came across this today. The wire goes behind the breaker. Is this considered a double tap?
Not that I can see, was it a GFCI?
No if it is a GFCI/AFCI, but that IS a double lug on the bus bar!
No, it’s the neutral pigtail for a GFCI or AFCI circuit breaker. As JJ stated there are two visible double taps on the neutral bar.
