Never understood this method of construction
Here in middle to northern GA flatwork contractors pour concrete flatwork in garages with a recessed pocket about 1 foot inset from the driveway that is flush in grade and then elevate the rest of the garage slab about 1 to 1.5 inches. Most often after several years or more, you find moisture wicking and moisture damage at the lower garage front walls. I understand why they think it would be a good idea, but it’s a terrible method.
We never did that in MI or FL, 2 states I’ve done construction in. Do any of you see this method in your State(s)?
From today’s inspection.
Nope, not in my area. Like you said that’s a terrible idea. Around here, (when done and it is not always done), the drop is at the Exterior of the overhead door, and it is not that much.
Are you in a hurricane zone where they would be using it to add wind resistance to the bottom of the garage door?
I should’ve said it’s not every single home. But it’s a sizable amount that are done this way. I’ve seen it in in foothill regions of adjoining states like SC, NC, AL, and TN. I recall seeing this starting in the late 1990s and continues to this day. I was just curious how far this disease has spread :laughing:
We are not. We mostly inspect residential in the metro ATL and north GA areas.
The little recess of the concrete at the door and the rest of the slab being elevated is fine. That’s how it’s done 99% on new homes in my area of central NC. The whole point is preventing water from getting into the garage when the driveway is flat just outside the garage and you get heavy rain and wind, or the garage is located at the side of a hill and the door faces up the hill, to try to prevent water from running into the garage.
The part that is wrong is the walls are framed to the slab instead of being elevated on an actual foundation that sits above the slab. The slab of the house should step down into the garage slab. I only catch the problem you are showing normally on that central little wall between the two garage doors around here. The rest of the garage walls are almost always elevated above the slab a few inches at least.
The trend is not going away…
I don’t see this method much, but agree with Yu. Around here, the foundation walls are almost always on a stem wall, so no issue.
Ditto that!
Curious though, as I can’t tell from the pics…
Are the Lower ‘Pocket’ and the elevated ‘Slab’ both made from a single pour… Or… is the lower ‘pocket’ (base/foundation) for the walls a separate pour from the garage ‘slab’ (e.g. Floating)?
I have seen this (similar) in my area by only one certain contractor. The slab is lowered only where the doors are located so the water does not travel over to the wall(s), which is the reason for this in the first place.
It seems like a good idea, however to me the about one inch (minimal) rise, I can’t help but see it as a potential tripping hazard.
This particular one was a continously pour with the garage slab. But, I’ve seen the lower shelf poured independently and continuous with the driveway.
I’ve seen dozens of iterations and methods for the flatwork. They are all over the place here. But this method shown in the OP always shows signs of moisture issues at the lower front garage walls.
this is how the builders usually do it around here
