New Citizens 4 Point Ins. Form 2025
https://www.citizensfla.com/documents/20702/48575/4-Point+Inspection+Form.pdf/e8c41965-f225-37fc-b451-4d360ee30b77?t=1743432185731
Theres nothing new about that
I think you have to report stranded AL AND denote what it feeds (usage)
I never did that
There are several changes on the form if you look:
The wire types, the plumbing type (list expanded with cast iron, ABS, date of PEX), age of drain system, the water heater date, fireplace actually there or not.
Oh, I guess there are a couple new items, my bad..
So I assume with the 50s and 60s wiring with the fabric sheathing and thermoplastic insulation, that would be checked now. Because I never classified that as “cloth”
thx
That is very odd. I didn’t notice a difference when I looked at it either. I use a different format for my 4-pt and it already had the exact same verbage for the aluminum wiring, age of the water heater has always been on there as well as all the plumbing options. Only thing that is different would be the age of the PEX, but if it was updated it would already be put in the date of re-pipe section. I have been using this version for the last seven years.
