Any suggestions on the type of report to be used for new construction inspection ? Thanks
Kevin Saunders
Clear View Home Inspection,LLC
Kevin Saunders
One that is clearly building code based InspectionDepot currently has the best reporting system. Good luck with your expansion into New Construction inspection if you approach it correctly it is very rewarding if not you will be very disappointed.
