New image added to the free Gallery: Common Types of Residential Wiring
Standard armored cable does not have a “grounding wire”. It has a thin bonding strip that is typically cut off or folded back and it not connected to anything. Calling it a “grounding wire” the same as with the other cable type implies that it needs to terminated.
The UF cable image depicts a 2 wire with ground but the label on the jacket says 10-3 WITH GROUND.
Updated: Common Types of Residential Wiring - Inspection Gallery - InterNACHI®
Refresh image.
Thanks fellas!
