New shingles over old spaced sheathing
A builder stripped a shake roof of all the shingles, left the spaced sheathing. Then put down OSB and installed asphalt shingles. The client is concerned this would cause problems. I can’t find any documentation that says the builder did anything incorrectly. The shingle manufacturer just says to strip the old roof to “an acceptable deck”. Do y’all think the roof is good?
What you describe the builder did is fine.
That’s very common practice. For both the contractor & homeowner.
This :index_pointing_up::index_pointing_up::index_pointing_up:.
Thanks everyone. Just wanted to verify.
Sounds like they followed best practice with older homes with spaced “roof boards.” Best to put down a full OSB deck over the top, otherwise you can have quite a few shingle nails that don’t hit any wood.
Frank. Not knowing the full installation process, verifying, is guessing.
A little more to it than installing OSB atop Skip Sheathing and asphalt shingles.
How was the reroofing process done please. Any images?
