system
(system)
October 21, 2005, 12:00am
Originally Posted By: jonofrey This post was automatically imported from our archived forum.
http://www.nachi.org/bbsystem/usrimages/D/DSC07708.JPG ]
Image: http://www.nachi.org/bbsystem/usrimages/D/DSC07709.JPG ]
– Inspection Nirvana!
We're NACHI. Get over it.
system
(system)
October 20, 2005, 12:00am
2
The secondary may have been on the drip pan. . .
Which is allowed by IRC 1411.3.1
-- Jeff Pope
JPI Home Inspection Service
(661) 212-0738
system
(system)
3
How does the condensate come out of the evaporator coil?
system
(system)
4
Basically, it spills over the edge of the cabinet if/when the primary becomes obstructed.
If there is no "built in" auxiliary pan, this external pan is required.
-- Jeff Pope
(661) 212-0738
system
(system)
5
I usually see them plumbed with a piece of pvc leading into the secondary drain pan.
system
(system)
6
Nice, but not necessary.
-- Jeff Pope
(661) 212-0738
system
(system)
7
Originally Posted By: dvalley This post was automatically imported from our archived forum.
John,
That rusting you see below the pressure line and the pan below tells me that the insulation tubing is not installed right up to the shell of the air handler.
I always tell my client to add additional insulation to the pressure line to prevent condensate dripping. I'd also recommend they remove the aluminum tape at that area, so the insulation can penetrate the housing.
--David Valley
MAB Member
http://www.masscertified.com
