Originally Posted By: rking
Loonmeister,
I have, and I suspect most tohers have as many code books as they can afford to have and a lot of other reference material for any house system.
There are a couple of guys on this board that I know have the NEC because they can post quotes from it!
I have the Canadian version as well.
Up here there is an organization called CMHC ( Canadian Mortgage and Housing Corporation) that underwrites? mortgages for homebuyers with less than a 25% downpayment they have a multitude of publications out dealing with everything and anything to do with construction. I have quite a few of those publications in my library.
I would imagine that a few of those books would be applicable in your state as well. You can check out their website at
www.cmhc-schl.gc.ca
I am not sure if there is an organization down there that is the equal to CMHC but if there is I am sure that someone will tell you about it here.
Gerry Beaumont seems to be chock full of references for websites and information so now... Over to Gerry!!!!
Muskoka Home Inspections
"Wisdom is the Anticipation of the Consequences"
Steering Committee Member At Large
