Originally Posted By: phughes
Is there a standard minimum number of receptacles that should be on a 15 or 20 amp circuit breaker?
Is there a good testing device for an Arc protector?
Originally Posted By: jpeck
Jerry Peck
South Florida
Originally Posted By: dbush
Dave Bush
MAB Member
Originally Posted By: Bob Badger
phughes wrote: |
Is there a standard minimum number of receptacles that should be on a 15 or 20 amp circuit breaker? |
Bob (AKA iwire)
ECN Discussion Forums
Mike Holt Code Forum
Jerry Peck
South Florida
phughes wrote: |
Yup, I find it all the time. If you place a tester on a GFCI receptacle, the unit won't pop, but push the button, and guess what. Everything looks just perfect. |
Bob (AKA iwire)
Jerry Peck
South Florida
Bob (AKA iwire)
tgardner wrote: |
I have run across GFCI outlets that still light my tester after the test button trips out. I say it is not functioning properly and needs.......
I do not trust the test button either as a result. TG |
Quote: |
Some installers and inspectors question the efficacy of the internal GFCI test circuit either because they mistakenly believe the test is merely a mechanical check or because the internal test and the commercially available GFCI testers may give different results. Their skepticism is unwarranted |
Bob (AKA iwire)
Jerry Peck
South Florida
Quote: |
The HWESB recommends these steps for testing GFCI's:
1)Visually inspect the device for obvious defects and broken parts (do not continue if the device is broken!). 2)Press the reset button (or check for voltage at the device) to determine if it is tripped. 3)If device was found in a tripped state (no voltage, or you hear or feel a "click" when you press the reset button), be suspicious - ground fault protection may be inoperative when voltage is present after the device is reset - DO NOT USE until you complete the following test sequence! 4)Press the test button and observe that the device trips (hear or feel a "click"). 5)Verify no voltage at the outlet (a voltage meter, load device, or trouble light will work). 6)Press the reset button and verify that power is restored. |
Bob (AKA iwire)
Originally Posted By: rmoore
Richard Moore
Rest Assured Inspection Services
Seattle, WA
www.rainspect.com
Jerry Peck
South Florida
Richard Moore
Seattle, WA
www.rainspect.com
