Observed this dark staining on the crawlspace floor around an old wood fireplace chimney. The white at the edges is efflorescence. No dampness in the dark stain area.
Any thoughts on the source?
My guess would be water mixed with creosote and soot, leaking out at the base of the chimney, even though it was dry at the time of inspection.
Rain running down the flue, no chimney cap.
Yep…What they said. ^^^^^^^^^^
What Scott said…
But it is still water intrusion.
It doesn’t need to be coming from above, either…
Water, Likely perimeter drainage system.
Lot slope in that area?
