Okay Severe back drafting at Water heater
Okay here we have a Furnace and the water heater coming in from the right.
  1. Vent clearance issues (Got it)
  2. Insolation in a bad place (Yup)
  3. I don’t thing the vent is in the correct place because the room have plenty of air (Louvered door) I know the vent is usually on its way up when water heaters are connected to the vent but there is no space for that here.
  4. Should just stop at recommending an evaluation by an HVAC specialist for the venting AND a plumber for the WH vent and plumbing (expansion tank) and let it go?
I would recommend a mechanical contractor to correct the setup.
Yup. Thats what I ended up doing. I need to keep from getting too deep somtimes. Thank
Sergio Barajas at
Always Welcome, Home Inspections. LLC.
Maryland.
I don’t see any evidence of backdrafting at the water heater vent hood. What do you see? Caviat; It appears the top of the water heater was dusted recently. However, I don’t see any backdrafting evidence on the vent hood. Did you test for backdrafting with a match or smoke stick, using these procedures?
It is amazing how many inspectors take this as evidence of “severe” backdrafting…
