Living in the State of Oklahoma with dry stack stone on the exterior walls of your home you may have moisture intrusion problems within the inner wall cavities of your home and not know it until the problem starts indicating to the interior dry wall and that is usually to late to prevent organic growth from growing inside the walls and the decay process of the wall studs.
Freedom Express Inspections and CMOR Thermography recommends having the exterior walls checked for moisture penetration on all dry stack stone installations
