# Older ducting..good air flow...question
**URL:** <https://forum.nachi.org/t/older-ducting-good-air-flow-question/53916>\
**Category:** Inspecting HVAC Systems\
**Created:** [November 5, 2010, 6:43am UTC](https://forum.nachi.org/t/older-ducting-good-air-flow-question/53916 "2010-11-05T06:43:07Z")\
**Posts on this page:** 3\
**Page:** 1
<div class="post-metadata">
**Author:** ![dnasser](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/dnasser/32/1208_2.png) [@dnasser](https://forum.nachi.org/u/dnasser)\
**Post date:** [November 5, 2010, 6:43am UTC](https://forum.nachi.org/t/older-ducting-good-air-flow-question/53916/1 "2010-11-05T06:43:07Z")
</div>
Home built in the 1960’s, at some point central air was put in.
The ducting is of older style materials. Do I recommend a licensed
HVAC contractor to evaluate ? There is Good air flow at all the registers.
David
[http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda190.jpg](http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda190.jpg)
[http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda188.jpg](http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda188.jpg)
[http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda191.jpg](http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda191.jpg)
[http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda192.jpg](http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda192.jpg)
[http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda193.jpg](http://i187.photobucket.com/albums/x296/dawlita/Misc/Aleyda193.jpg)
**Author:** ![jfrederick](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/jfrederick/32/58314_2.png) [@jfrederick](https://forum.nachi.org/u/jfrederick)\
**Post date:** [November 5, 2010, 1:02pm UTC](https://forum.nachi.org/t/older-ducting-good-air-flow-question/53916/2 "2010-11-05T13:02:59Z")
</div>
Evaluate what?
**Author:** ![cbottger](https://sea2.discourse-cdn.com/internachi/user_avatar/forum.nachi.org/cbottger/32/206_2.png) [@cbottger](https://forum.nachi.org/u/cbottger)\
**Post date:** [November 5, 2010, 1:24pm UTC](https://forum.nachi.org/t/older-ducting-good-air-flow-question/53916/3 "2010-11-05T13:24:13Z")
</div>
> [@dnasser](#):
> David
As a Hi hired to perform a visual inspection I don’t use the word Evaluate in my reports I write what I see as wrong.
If the joints were leaking air that would be on the repair list If the ducts were not insulated as required for a non-conditioned space that would be on the repair list. Does not matter when A/C was added to the system it was always required to insulate ducts.
I see a lot of older duct work that had central heat only in its original conception and has just the fiber glass wrap no vinyl or paper outer wrapping I don’t put that on the repair list but I do make a recommendation to upgrade to conserve energy
