7:00 mark, you already know there will be moisture intrusion because… the GRADE?
hahaha!!!
11:30 same house, inside… so it’s all because of the grade and could NOT possibly be that some exterior waterproofing of that wall is needed? REALLY?
14:40 next house, inside, a corner… has mold etc… so NO chance, no possibility that some or all the water isn’t getting in due to an exterior cracks or other direct opening in the house/B wall etc, just all about grading huh?
17:40–17:50 ish next house, again…lol, so NO possibilty that there may be an exterior crack in wall, at neat corner or opening(s) under/around that door etc??? Just better drainage huh?
19:35 same house, SUMMARY…
- repair grading
- install ext-drainage
3.install int-drainage
NO chance there may be 1 or more cracks in wall or other openings into house that can allow water in? You don’t want to bring up this possibilty huh? Just grade, drainage huh? PFT!!!
29:40 next joint, see F-wall inside? He says, 'Moisture and efflorecence coming through wall"
… his SUMMARY, excuse me, the EXECUTIVE summary…
—repair drainage AND exterior wall
well lol, what does THAT mean? What are you saying?
You saying exterior waterproofing done and backfilled correctly of this area or you talking about playing games?
Sure sure sure, try n divert some water away, FINE!!! But you are NOT giving peeps watching this video or the CLIENTS everything they need to know about leaky basements/crawls, nope!
