and then the next page says “code requires ventialation for each enclosed attic space” but the page just before that said its okay if the attic is unvented as long as its air tight and a few other requirements, so my question is, which is the correct answer??
The attic must be vented, unless it is a conditioned space. Depends if the insulation is separating the attic space from the living space, or if the insulation is separating the attic from the exterior.
If it has spray foam insulation along the bottom of the roof decking, it is considered part of the building envelope, and there should be no venting to the exterior, and there should also be conditioned air provided to the space.
FYI, that might be regional. Not required in my state. (though I think it is best practice to condition the space)
