open hot
Originally Posted By: mike garcia
Hello
If a outlet shows no reading on a circut tester [open hot] because
it don’t work is this considered a hazard . if yes why if it don;t work
Thanks
Originally Posted By: tschwalbe
If it does not work there is a reason for it and it usually is not good. If you have a loose hot it would be a fire and safty hazzard. If it does not work or is not needed it should be properly disconnected and a blank cover put over the box. No gray area here!
I don’t see the hazard but it is something you can note. Just be sure this isn’t a switched outlet that is “off”.
Originally Posted By: Blaine Wiley
As Greg said, look for a switch or a tripped circuit breaker. If neither is found, write it up as a nonfunctional receptacle and recommend repair.
Originally Posted By: jgriffith
The first thing I do is probe it with my inductive tester to be sure there is no voltage present. icon_cool.gif
Originally Posted By: jpeck
Not working is not necessarily a hazard, but it IS something you write up - because it is not working, and because it could be a hazard.
It might not be working because ...
... it may never have been connected.
... there may be a switch for it you can't find.
... that circuit could have been abandoned at the panel for some reason (but this would lead me to suspect a problem with the circuit wiring).
... it could be off a GFCI someplace, and you can't find it.
My point is, it is not necessarily a hazard, but it could be a hazard.
Jerry Peck
South Florida
jpeck wrote:
... it is not necessarily a hazard ... it could be a hazard.
I agree ... if there are no tripped breakers or obvious switches for the receptacle, it would be a "defect" and possibly a "safety concern" also.
Just my opinion and 2-nickels ... ![icon_wink.gif](upload://ssT9V5t45yjlgXqiFRXL04eXtqw.gif)
Robert O'Connor, PE
Eagle Engineering ?
Eagle Eye Inspections ?
NACHI Education Committee
